Got a question: found some bug while doing data tables with filter. When I am doing the filtration, Amplitude shows users that do not fall under stated filters. What might be a problem in such case?
Hey Yuliana Turchyn
Are you filtering on an user property?
Most likely that user’s current value for the selected user property could be different than the value reported during the chart interval. This makes the user get filtered on both those property values if they have reported different values across the time interval, which is a common behavior in an event seg chart.
Hey Saish Redkar,
The user’s property I am filtering on is unique, it cannot be changed across the time interval
Saish Redkar I have the same situation, if this is the case, do we need to change anything related to time? I’m in a Data Table view using an Event Property. Thank you!
