Hey @demarshall
If I’m understanding your use case correctly, then using the User Sessions chart would be a better option.
You can create a demo sessions chart like this - https://analytics.amplitude.com/demo/chart/new/0cwrdll and then extract the cohort of users from the desired time spent bucket. e.g. extract cohort of users who spent 5-10 mins in your app in the last 7 days.
Hi @Saish Redkar,
Thank you for your reply. I was aware of the user sessions chart, and that does come close to the result that I would like -- however, the issue is that the cohort extracted from this chart is always a static one. Therefore I would have to consistently create new cohorts from this chart to keep this group of users up-to-date.
Are there any solutions that would enable me to create a dynamic cohort with these specifications, or similar?
Thanks.
Hi @demarshall ! Chiming in from Amplitude Support team :)
Good thought on derived properties but, for derived properties, it’s not possible to take a property value from one event and subtract it with a property value from another event to get time between the two events. The derived properties create new properties based on properties that exist on one event itself. As such, unless you tracked the timestamp of the previous event on the current event (which will likely prompt you to touch code since this is currently not the set-up), derived properties won’t work.
Saish’s suggestion is really good and probably the best workaround given the current capabilities and if you don’t want to touch code. However, it is the case that the cohort will be static and there isn’t a way to create a dynamic cohort with these specifications.
I welcome you to share your feedback here regarding ability to track time between events as a property without needing to touch code: https://community.amplitude.com/ideas
