Branch Integration issue
  • 25 April 2023
  • 155 views
Hi team,
We’re using Branch SDK to integrate app INSTALL & REINSTALL(Critical events) into Amplitude. But Amplitude is not tracking those events for some reason, Could you please help us to resolve this.  FYI Other events are tracking like OPEN, & Custom events.
Best answer by belinda.chiu 5 May 2023, 19:08
Branch.Io Team has evidence events are successfully sent to Amplitude.
@murali_coto thanks for writing in about this! I’ve opened a ticket with our tech support team to look into the issue.
Hi @murali_coto ! Thanks for reaching out and happy to help!
Branch INSTALL and REINSTALL events come to Amplitude via the Attribution API which is a special API endpoint that has a couple of requirements. I highly recommend reading through this troubleshooting doc which will guide you through all of the steps you can take to troubleshoot this:
https://help.amplitude.com/hc/en-us/articles/360051234592-Troubleshooting-Missing-mobile-attribution-install-uninstall-events-
For a quick tl;dr, there are 2 requirements needed in order for Amplitude to ingest attribution events:
  • An existing user in Amplitude with the matching IDFA, IDFV, or ADID
  • Mapping completed within 72 hours
