Reduce steps to obtain user properties
  • 9 October 2022
  • 90 views
Our team has a Lifecycle chart that shows users who were dormant this past week. I want to make it easy to reach out to those users and learn why they were dormant.
Right now on the Lifecycle chart, I click the Dormant Users bar → click View Users → click each User ID one-by-one → click See all other User properties → and then I can see which user it is!
Is there a way to surface the user property that enables me to identify this user (e.g. email or name) with fewer clicks?
Best answer by Saish Redkar 10 October 2022, 06:45
Hey @FounderTurnedDS
Lifecycle chart doesn’t support any group by clauses currently.
The best bet would be to click on the Dormant Users bar → Download Users. This will download the CSV of all your dormant users from that data point along with their recent user properties in a csv format.
Another option you can try is creating a cohort from that datapoint ( Create Cohort ) , use this cohort in an event segmentation chart and group by the email/name property to get an overview of those users.
Thanks @Saish Redkar! It’s simple, but the “download users” solution works for me!
