RANGES for Frequency
The Ranges feature works great. ⭐️ Here’s an example.
Segmentation: Song Plays measured as Frequency with custom bucket size of 5.
PROPSUM
The Propsum feature also works great! ⭐️ Here’s an example.
Segmentation: PROPSUM of points by user
PROPSUM Ranges
Is there a way to count my users by the sum of their points in ranges ❓
Example: Sum of Points - Point Range measured as Frequency with custom bucket size of 10,000 pts
  • 0-10,000 pts:            12,000 users
  • 10,001-20,000 pts:   20,000 users
  • 20,001-30,000 pts:   15,000 users
Thanks,
Anthony
Having the exact same problem! Any way to set the range or group by propsum?
Right below “sum of property value” there’s a “distribution of property value” option. Select that and then hit “set buckets” to group them into the categories you’re looking for. Here’s an example from our demo environment https://app.amplitude.com/analytics/demo/chart/new/d3nivyw7
Thanks @Beth Saunders. I think your chart is counting the individual events, though, and we need to count the users after we have summed the values for those users.
E.g., “How many users spent a total of $100 - $150 in the month?”
I think your chart works if you can only pay once/month, but if you make 2+ payments/month, then how to get the totals?
Aha, I see what you're trying to do. Unfortunately, we have no way of taking the total PROPSUM, only the individual event totals. In order to achieve this you would need to export the data out of Amplitude.
