How could I remove a chart from Dashboard?
  • 12 August 2021
  • 5 replies
  • 195 views
Userlevel 1
Badge +1
same as title
Hey @Bill
If you are the owner of that dashboard, you will see a “Settings” option on hovering over the lower right corner of the chart in the dashboard
Settings → Remove
You can then “Remove” that chart from the dashboard.
Userlevel 1
Badge +1
Hi Saish,
In the settings of a cohort within a dashboard, it doesn’t have the option to remove…
Bill
Hey Bill,
I tried replicating this and here’s what I found -
  • I am able to remove a chart added to a dashboard by clicking on its settings on the lower right corner.
  • However, I am not able to remove a cohort added to a dashboard, the scenario which you have highlighted above. The only options are the only you see in your shared screenshot. Not sure if this a weird behavior or a bug. Seems like the dashboard is treating a cohort  differently than a normal chart.
Tagging @Denis Holmes to investigate this one.
Hi @Bill ,
Thanks for the tag @Saish Redkar ! Bill, can you create a new Community post outlining the issue? That way, one of the team members can pick up the community post to investigate. Thank you!
Thanks, all! 😃 @Bill I’m Jeremie, the community manager. I generated a ticket here no need to post it again. The team will look closer, and we’re here to help!
