same as title
Hey
If you are the owner of that dashboard, you will see a “Settings” option on hovering over the lower right corner of the chart in the dashboard
You can then “Remove” that chart from the dashboard.
Hi Saish,
In the settings of a cohort within a dashboard, it doesn’t have the option to remove…
Bill
Hey Bill,
I tried replicating this and here’s what I found -
- I am able to remove a chart added to a dashboard by clicking on its settings on the lower right corner.
- However, I am not able to remove a cohort added to a dashboard, the scenario which you have highlighted above. The only options are the only you see in your shared screenshot. Not sure if this a weird behavior or a bug. Seems like the dashboard is treating a cohort differently than a normal chart.
Tagging
Hi
Thanks for the tag
Thanks, all!
