I am seeing a difference between what I filter and the data that is shown.
- Filters; initial_utm_medium does not contain cpc
- Data; there is a record exactly with that
Why could this happen?
Best answer by Loc Tran
View originalHi,
View originalHi
Thank you for the screenshots of this issue. Is “initial_utm_medium” an event property or a user property? Also, can this property value change when another event is sent to Amplitude?
The reason I ask is that when you download a .CSV of users, the file will contain each user’s most-recently sent user property values. I think this might be the cause, but let me know those first two questions and I can take a closer look! Thanks.
Loc
Hi
Is there any way to see this? Could I confirm this somehow? (that it doesn´t change)
Regards,
Tal
Hi
Thanks for your reply and apologies for the late response! You can do a user look-up and view their individual event stream and see what the value was at the time “Deal Won” was performed.
The user properties displayed with each event in a user's individual event stream capture the value of the user property at the time of the event. The exported file will show the most recent user property values. I think this user may have fired an event after Deal Won that had a value with “cpc” and that’s why you see it.
Let me know if you have questions or concerns!
Loc
Hi
Don’t worry. But that was exactly the case, we figured it out a couple of days ago.
