D60 and D90 retention
  • 3 March 2022
  • 437 views
With the retention chart I currently can only get retention up to day 30. How do I get retention beyond that? To day 60 and day 90?
Thank you!
Cheers,
Christina
Best answer by Saish Redkar 3 March 2022, 17:30
Hey @ChristinaLumi
On the x-axis, retention maximums are 30-day, 24-week, and 12-month retention respectively. You can try using custom brackets to define your retention intervals.
Here’s more on that-
@Saish Redkar  Oh yeah I did not know this feature. Thank you very much for this. It does work. Is there anyway to delete a custom brackets or rename it? I can’t seem to find an article on this.
Cheers,
Christina
Hey @ChristinaLumi
Unfortunately there isn’t a way to delete the custom buckets on our end. This can be done by the Support Team if I recall correctly.
I had actually submitted a feature request for the same while ago -
