Aggregate event properties
  • 24 January 2022
  • 593 views
Hi, I wanted to know if I can get the average or sum of an event property for some users.
For example, if the event playSong has a property songDuration, i want to know the average song duration for a group of users.
Thank you!
Best answer by Saish Redkar 24 January 2022, 22:40
Hey @ncoen
You can utilize the custom formulas feature to apply the desired formulas on your event properties in an Event segmentation chart.
Here is an example chart which visualizes the average song duration for the AmpliTunes demo environment using the PROPAVG formula - https://analytics.amplitude.com/demo/chart/new/wpg7xkm
You can also compute the property average using the Properties option in the Event Segmentation chart
Hi @ncoen ,
Glad to see this was solved by our power user @Saish Redkar ! Thank you, Saish! Your hard and tireless work is really appreciated! :)
