Hello!
Many a times I want to verify if I have synced a given cohort to the correct Marketo field. It appears that I'm not able to view the Custom Marketo Boolean Field after a sync is performed. Once you sync, the only option is to resync it or set up a new field for another sync. Is there a way to view this field after a sync is performed?
Ideally, seeing this field alongside the following details for a cohort will be helpful -
