Hi there,
I’m new to Amplitude and using the mobile SDK in our app. I’m also using OneSignal for messaging across multiple channels.
Currently, I’m trying to re-engage users that have no app usage in the X number of days, and trying to filter out anonymous users within a cohort.
Is this possible? I’ve tried different operators with multiple variants of “Anonymous User” as User ID but it doesn’t seem like Amplitude even sees the term or the word Anonymous.
Hi ​@SeanS
Anonymous Users are usually those without a valid user_id.
Try adding the “user_id is not none” clause in your cohort definition and see if that works out.
This worked. Thank you!!!
Thanks for hopping in Saish!
