How to add data source from the screen of "Send using the HTTP API"
  • 8 April 2021
  • 131 views
I do not know the next step to add data source from the screen of "Send using the HTTP API"
Could some one teach me the procedure until using this function?
Best answer by Saish Redkar 8 April 2021, 18:33
Hey @daiki
You will have to first send your events using a POST request as mentioned in there to test this out. I recommend you set up a test bucket/project if you haven’t done it already.
Once you have that working you will see the HTTP API appearing in your Sources for that test project as shown below :
@eddie.gaona has written a detailed post about ingesting events via the HTTP API here :
Hope this​ helps!​​​​​​
Hello Saish
Thank you for your guide.
I have already been ready for our Json file.
But I do not know which tool should I choose for post request.
and according to your direction, I am stoped and stucked at this screen.
Anyway, if you couuld, please teach me how to use and which tool should I choose.
Daiki
Sorry I solved this problem. Thank you for your help.
