Hey community,
I am using the Amplitude Data (Beta) under the Enterprise trial plan.
Has both the Taxonomy API and Govern Add On become the Tracking Plan functionality in Amplitude Data?
Thank you in advance!
Hey community,
Hi Elena — Amplitude Data (Beta) is the new home for tracking plan management, including features that are included in the Govern Add On like transformations. We are slowly rolling this out to both new and existing organizations. The Taxonomy API is not supported yet on Amplitude Data yet but we’re releasing an updated version that will be available in H2. Hope that helps.
Patrick
Dir of Product — Governance.
Hi
Thank you for your reply. A few follow up questions:
Thank you!
Hi
Wanted to follow up on Elena’s last question.
Great suggestions
