I’m looking at the docs for the export API which documents how to use an API key/secret key combo to authenticate with the API. Is it possible to use an API token to authenticate with the export API?
Best answer by Saish Redkar
View originalI’m looking at the docs for the export API which documents how to use an API key/secret key combo to authenticate with the API. Is it possible to use an API token to authenticate with the export API?
View originalHI
Looks like API tokens can be used to authenticate mostly to Amplitude Data.
Export API uses API key and secret key for authorization currently.
Maybe
Thanks
