Hello,
I am using the Webhook Destintation functionality on the data connections.
I send events through Webhook and I have found 2 issues constantly happening
  1. There are missing events and events that fail to be delivered for a missing property I’m using that is actually present. Then I go to find the specific event in a Segmentation chart, if I filter by that property being missed I do find some events but then when look deeply into those events they do have the property. Some events don’t even appear in the data connection counter and some of them fail with this error that is not accurate.
  2. Duplicated events. This is less serious but many events are sent multiple times to the Webhook
Many thanks for the help and clarifications,
Vicente
Be the first to reply!
