  1. Subj
  2. Can I receive credentials to connect to Amplitude data storage of my project ?
Hey @Ira F
If I’m interpreting your question correctly here, you want to know the ways to get access to raw data of your Amplitude project , correct?
  • If you are a paid customer, then you can setup recurring exports of your project data to the cloud destination of your choice ( S3, Snowflake, GCS ) directly from the Amplitude UI.
  • If you are not on a paid plan, then you can leverage the Export API and create your own custom ETL pipeline to store your raw data.
  • There is also the Query add-on feature which allows you to query raw data via a Amplitude-managed Snowflake database.
Thanks, @Saish Redkar , I too want know what is own storage of Amplitude - even if I not have direct access it can help me to evaluate speed.
Is it Snowflake ? - “Query add-on feature which allows you to query raw data via a Amplitude-managed Snowflake database.”
If I understand right this ad-on is not free. But I not found variant to pay for this ad-on only to use it with free plan.
I believe they have something developed in-house. You can read more about the Nova architecture here.
Saish Redkar, thank you again, it’s interesting
