Question
Specefic event is not sent to Amplitude
  • 26 July 2023
  • 0 replies
  • 94 views
I’m new with Ampliture (and integration with it). I’m using Java SDK to send evemts to Amplitude.
amplitude.setLogMode(AmplitudeLog.LogMode.DEBUG)
amplitude.setEventUploadThreshold(100)
// define event and send
amplitude.logEvent(event)
It should be noted that I use Kotlin with courotines.
I’m trying to import to Amplitude my latest events (e.g. for last 3 days). I can see allmaust all events in Amplitude but `first_result`. Neither in Data → Events tab, nor in User Look-Up page.
Debug mode shows that everything was sent correctly.
​​​​​​​SEND: Events count 100
RESPONSE: {
    "code": 200,
    "successBody": {
        "serverUploadTime": 1690390833497,
        "payloadSizeBytes": 74160,
        "eventsIngested": 100
    "status": "SUCCESS"
I’m sure that I set API key correctly.
Also, when I try to create custom event with this name I receive error “Unable to create an event with a name that already exists”
I’m out of options now and will be glad for help
Be the first to reply!
