Hey,
Does anyone have already set up a recurring data export to BigQuery ?
Here are the steps , but I’m stuck at step 2, can’t find the BigQuery destinations.
If anyone could help mec
Guillaume
Hey,
Guillaume
Hey
Export to BQ is available to only paid customers. Assuming you are a paid customer, this is how it looks for me under Data Destinations
I went to “View All Destinations” , which will list out all the available ones and searched for BigQuery
If you are a paid customer and still not able to locate this, then you can reach out to your CSM and check if any feature flags need to be enabled for your account.
Hi Guillaume,
Saish covered all the bases let us know if you have questions!
Sydney
Hi Saish and Sydney,
It explains everything, thanks for letting me know :)
Cheers,
Guillaume
