We are using the Google Tag Manager template to send our website events to Amplitude. We have a small subset of events that we’d like to send to a new project, while also continuing to track them in our current production project. When I preview this in GTM, I find that the test event only goes to the new project, not the production project. Is there a way to send the same event to both at once and have it show up in both?
Just in case anyone runs into this issue and needs to know how to fix it: we weren’t including the instance name for the new project in the second set of tags. It turned out to be an easy fix!
https://www.docs.developers.amplitude.com/data/sdks/android-kotlin/?h=instance#multiple-instances
