Now it is impossible to send more than 2 events from the page, is there such a possibility at all or is there a limitation on sending events (no more than 2 from the page)?
I don’t think it’s true that there would be a limitation of 2 events per page. What makes you think there is such a limitation?
Because if I send 4 events instead of 2, then the new ones overwrite the previous ones, that is, the last 2 events out of 4 are sent
Hi
Does this answer your question? How are you currently sending data to Amplitude?
Are they the same event type and timestamp by chance?
analytics.amplitude.com analytics.eu.amplitude.comEnter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
