Pulling Events From Another Amplitude Project
  • 13 March 2023
  • 116 views
Is it possible to pull events from a different Amplitude Project into another?
Best answer by Saish Redkar 14 March 2023, 04:53
Hi @taylor.merrick
AFAIK, the only direct approach from an end user perspective is to export data from project A and then backfill this data via Batch API to your new project B.
Here are some resources on this process :
https://help.amplitude.com/hc/en-us/articles/360052385792#h_01EQKNGMMZBBSC53FD36GT7FBK
https://www.docs.developers.amplitude.com/analytics/data-backfill-guide/
I’m not sure though if there is an alternate way by which the Amplitude Support Team can directly do this on their backend for certain cases.
