Dear community,
Apologies if I’m asking an already asked question here.
Is there a way to view the average of a ‘formula’ event over the users. Specifically, I have a parameter ‘like_ratio’ that is generated as like / (like + dislike).
I am interested in the average like_ratio per user - not weighted by likes and dislikes, but just a clean average.
If I make a segmentation chart of totals_like / (totals_like + totals_dislike) I get a chart weighted by activity (the most active user will weigh more in the result).
Is there a way to create the average of the per user like_ratio?
I have tried the avg(like) / (avg(like) + avg(dislike)) but I get a wildly different number from what I get when exporting user data and taking the avg(like / (like + dislike))
Thank you!
Hello !
You need to add the amount of users to your like_ratio.
Thus, to calculate the average like_ratio per user, I would first try computing a formula using:
  • TOTALS_like / (TOTALS_like + TOTALS_dislike): this formula allows you to get your “like_ratio”
  • AVG(): allows you to get the average event triggered by user
The formula would be “AVG(like_ratio formula)”. However, it does not seems to work as we cannot use AVG on another formula.
Then, I would try to add an extra event to determine the amount of unique users (using the most common event occuring such as a view page if you are using a website). You can now compute the following formula: like_ratio / UNIQUES(common event).
This should look like that:
(TOTALS_like / (TOTALS_like + TOTALS_dislike))/UNIQUES(view page)
In my opinion, this formula should get the average you are looking for.
Hope it helps!
@Ingmar Oemig Thanks for your post! Matrak, provided a suggestion for how to calculate your average ‘like_ratio’  per user:
At this time you cannot apply the AVG() formula on top of another formula calculation, therefore the above suggestion is the closest option available for calculating the average like_ratio per user. If this does not suffice, I am also happy to file a feature request on your behalf.
I hope this helps!
-Jacenda
