I have a collection of events associated with session_id.
However, when selecting the UserSessions tab, no sessions are displayed. I have attempted to view both events performed within sessions and standalone sessions.
What did I do wrong?help, please
Hi Ruslan! Are you sending IDs as milliseconds since epoch? If you’re using the HTTP API, make sure that it is correctly formatted. From the help center:
Session IDs for events sent via the Amplitude SDKs are automatically generated and managed. However, for events sent via the HTTP API, Amplitude defaults to a session ID of -1. This means the event is excluded from all session metrics.
Here is my request in Amplitude
Did I understand correctly, do I need to add the “time” key in milliseconds?Thanks for the help
It looks like all your Session IDs are coming in as -1, so I’d recommend double checking that your code is setting a unique Session ID for each session because it looks like Amplitude is setting them to the default -1, which will exclude the event from session metrics.
