The definition of Saved segment is quite limited, for example it is not possible to:
  • Exclude users who performed an action
  • Filter events based on their parameters (and not just the event name)
Is there any workaround?
Thanks
Hey @JoeKDoe
  1. The “Exclude users who performed an action” is something which can be easily done using behavioral cohorts. This isn’t possible using Saved Segments.
  2. When you say “Filter events based on their parameters” , do you mean that you want to build a segment for users who performed an event and select a specific event property for that event? If that’s the case, then it’s possible.
 Most of the limitations of saved segments can be addressed using behavioral cohorts, which I just realized isn’t available on Amplitude’s Free Plan ( Platform Specialists, correct me if I’m wrong here)
For #1.
As @Saish Redkar stated, this is possible with Behavioral Cohorts quite easily. A possible workaround for excluding users would be to filter for users “who performed” X event < 1 time. Here is an example: https://analytics.amplitude.com/demo/chart/new/f9hs4d3
Filtering for users “who performed X event” < 1 time
For #2.
Saish has a great approach to “filter events based on their parameters” which is possible as he has mentioned!
@jarren.patao
That’s a nice workaround ⚡️  for #1. I almost missed the fact that we can still use the < , > operators to achieve that.
Do you see any edge cases cropping up if we use the = 0  vs < 1 clause for excluding users who performed event X ? They both seem to align logically as expected as seen here - https://analytics.amplitude.com/demo/chart/new/apx7ee2
Thanks! <img class=" src="https://dowpznhhyvkm4.cloudfront.net/2021-02-08-11-28-12-84e623a2ac/dist/emojione/263a.png" width="18" />
Hi @Saish Redkar, using “= 0” vs “< 1” should effectively behave the same for this type of analysis!
Regarding #2: I have a free plan and don’t see this option (to build a segment for users who performed an event and select a specific event property for that event). Is it available only for Pro plan?
Hi @mqklin - yes, that’s a feature only available for our Growth or Enterprise plans! Have you checked out our Scholarship plan? You might be able to qualify and get access to these features: www.amplitude.com/startups
I know this post is solved, but it hits on a topic I can’t see clearly explained anywhere. What is the difference between segments and cohorts?
I noticed that when using a cohort defined by a user having a specific user property in the last 30 days, then I am not able to look at users from a year ago that had that value unless they are also active now. So even though my chart has a date range of 1 year, if the users from a year ago are not recently active, it looks like I had no activity before the last month.
Is the segment choosing users to include or exclude based on the value at the time of the event, whereas once users meet the criteria for a cohort, they are always included, even if their user property value changes?
Is this something that works itself out over time? Should I be using saved segments until the cohort has lived for a year?
