Min_id_length not working for track_event api
  • 6 December 2023
  • 89 views
Hi there, I’m getting the error: “Invalid id length for user_id or device_id”,
while calling the track_event api. I passed the min_id_length to one, still I’m getting errors for user ids < 5 character and I have user ids less than 5 character. Here’s the request, Please help me with this.
AmplitudeAPI::Event.new({
user_id: user_id,
event_type: event_type,
time: Time.now,
insert_id: SecureRandom.uuid,
event_properties: event_properties,
options: {
min_id_length: 1
Best answer by Saish Redkar 7 December 2023, 19:51
Hi @Himanshu Itoria
Can you try to set the min_id length in the options parameter during your SDK initialization?
Thanks @Saish Redkar,
I was using amplitude-api ruby gem in rails, where that option wasn’t working, I’m just simply making a POST request on the api now, without use of any gem, the option works fine.
HTTP API supports the options parameter where the min_id length can be overridden.
