Question
Import S3 not working
  • 24 January 2024
  • 71 views
Hello,
I encountered an issue in adding additional data source from S3.
the error I get:
for context I have another source from the same bucket that is currently working.
When I looked into the source of the problem I took a look at amplitude’s docs:
amplitude docs - S3 import guide
In the policy that is there it seems that the S3 integration need the following: s3:ListObjects
but s3:ListObjects is deprecated, the error from the policy editor in AWS:
I would like to know if this is the cause of the problem? could it be on amplitude’s end?
the currently running source is working fine.
Thanks for any help in advance!
Trying to bump this up, I still have an issue
We are facing the same issue, all permissions were set following documentation but something wrong is happening during pattern configuration on data converter.
I even set more permission trying to solve the problem but no success.
