Hello! Do I understand correctly that in order for the number_of_projects to increase by one each time the event is triggered, I just need to send `identifyEvent.add('number_of_projects', 1);`? Or I'm wrong? Because I read that the data in amplitude is immutable.
Or should every time you send an event about a user joining a project just send a numerical value corresponding to the number of projects at the time the event was sent?
Identify.add
Be the first to reply!
analytics.amplitude.com analytics.eu.amplitude.comor
