I’m trying to integrate Amplitude with Zapier / make or other tools alike. I’d like to once a day capture results from my charts, and process them with automation tools like Zapier. Has anyone done anything like it? Do you know if I could find any tutorials about it?
Hey
Looks like you are trying to create a Zap based on results from an Amplitude chart?
I couldn’t find any native integration of Amplitude and Zapier, although there are many custom third party apps which can do this I believe.
The easiest solution which comes to my mind is to use the Dashboard REST API for getting datapoints from your existing chart ( or creating one on the fly) and then posting these results to the suitable Zapier endpoint.
Let me know if I have interpreted your use case correctly here. Hope this helps.
Agree with
Does anyone know, how to get data from Amplitude to spreadsheet via Make?
Thanks for suggesting the alternate route,
https://www.make.com/en/integrations/amplitude/google-sheets
Not sure if you already ran into this one.
