Hello! I am new to Amplitude. I added custom properties for my custom events. How do I display them in Amplitude?
This is what I see now in property details:
I want to see property details, which I suppose should be displayed as a string somewhere.
Page 1 / 1
Hi @Palina Chernavtseva
Data UI won’t actually show you the values that the property is capturing, if that’s your goal.
If your data ingestion is live, you should be able to create a basic event segmentation chart using the desired event and use group by on this event property see the captured values.
Let me know if this was what you were looking for.
Thanks, @Saish Redkar, that’s what I was looking for. Now the question is how to create this chart
You can go to Create → Segmentation to create a new event seg chart.
