How to Concat a text value using Derived Properties?
  • 13 September 2021
  • 169 views
Userlevel 1
I want to concatenate two properties with a “/” in the middle. When I try using CONCAT(property-1,property-2), it works fine. However, when I try using CONCAT(property-1,”/”,property-2), it doesn’t work. Could soemone let me know what is the issue here?
Thanks a lot!
Best answer by jj41 13 September 2021, 21:41
Userlevel 1
Nvm, I tried using CONCAT(CONCAT(property-1,”/”),property-2) and it worked.
Badge +3
Glad that worked out @jj41 ! Thank you so much for sharing your findings here as well!
