Hello,
I’m currently testing with amplitude, and I’m not getting the time record according to the local timezone I’m in. Is there a way to change timezone?
Thanx in advance.
Hello,
Thanx in advance.
Go to Settings (bottom left corner, in the navigation pane) → Projects → choose a project. You should see this:
Note that this is project specific.
