I want to get data for what is the time difference between each login for every customer
using which graph i can generate this..
Best answer by Saish Redkar
View originalI want to get data for what is the time difference between each login for every customer
View originalHi
I also highly recommend our on-demand courses in the Amplitude Academy (Start here: https://academy.amplitude.com/page/start-here) You’ll be an expert in no time! We also have live training coming up!
not helpful!. i did not get it, how do i achieve it 😓
Hi
Hey
Try using the Retention Analysis chart’s Usage Interval view with your Login event and the appropriate time interval.
