how to measure How many unique events triggered through in a single given session
Best answer by Zhenia Semenina
View originalhow to measure How many unique events triggered through in a single given session
View originalHi
i want to track all events triggered through single session while example on academy covers events triggered between particular date.
now how do i get this.
Hey there
However, you could try and use custom formulas.
I've created an example chart here where we're looking at total active events/total session ids:
You can check how our Custom formulas work here.
We also do have a metric called Distinct Property values per User in Event Segmentation chart which graphs how many different property values each user triggered on average, e.g. the total sum of unique user-distinct property value pairs divided by the number of users. Not sure if this is what you're looking for exactly but we also have a few other metrics on the property value too - see https://amplitude.zendesk.com/hc/en-us/articles/230290208#metrics-bottom-module.
So grouping by the property like Session ID might be another option.
best,
Zhenia
Thanks a lot.
Hey
I haven’t used this feature personally, but you can also try using the User Sessions chart on the Count by “Events performed within sessions” clause. eg.https://analytics.amplitude.com/demo/chart/new/fegloqp
You can read more on this feature in here.
