I use the following code in my Flutter app / Dart:
   Amplitude.getInstance().setUserId(userID, startNewSession: false);
Amplitude.getInstance().logEvent(actionName,
eventProperties: {
'pageName': pageName
When I check the Event Stream, I see the pageName property as an Event Property.
But when I attempt to create a chart to GroupBy page Name for a given actionName...I don’t have that option.
Here is what I see currently (how can I edit my post?)
Hey @assembly
From what I understood from a previous post, I think querying on “Any Event” with event properties is possible only if you are on a certain plan.
Only Enterprise, Growth, or Scholarship plans have the ability to filter/group by event properties on aggregated events like “Any Event” as per Belinda’s reply on this post.
I’m not 100% sure about this since this post is almost a year old.
Can you check if you are able to see event properties under the actual event rather than “Any Event”?
Yes this corrected it.
