Hi community!
I’ve tried to do this by myself, but I’m failing miserably. So, first of all, if I install a simple javascript tag for Amplitude in GTM, I’m able to generate and get my events with my API key and everything. So, I generally know how to do things.
But here, I’m struggling with the Amplitude tag from the Amplitude Template available in the Google Tag Manager library: I’m setting up everything with my api key, my Amplitude tag is firing but nothing is getting sent to Amplitude.
I’ve set up as a trigger my GA4 events, and I have set up the Amplitude tag type to “track”, and under there I’ve set up the Event Type value to {{Event}} so that I get the name of my GA4 event (I’ve checked in my data layer variable, the Event variable is set correctly).
But my Amplitude is receiving NO data when I’m doing this :(
What am I missing?
Best answer by nblaisot
