Get events performed by all users
  • 6 April 2023
  • 102 views
I’m trying to obtain a report listing the events triggered by any users (and not users who triggered an event). Basically I want to get the frequency that a specific event is fired and see the custom properties I set for each one, so I can filter them. Is there a way to do that?
Best answer by tsegalla 6 April 2023, 18:57
Userlevel 3
Badge +5
Hi @tiagolbassani,
One way you can do this is by exporting your taxonomy of Events and Event Properties.  The export will give you a list of all Events, the Event Properties that exist underneath them, and additionally a column showing you the volume that Amplitude has received for each Event in the last 30 days.
More info here.  Let us know if you’re looking for something different.
I want a report containing all events that occured and their properties
Userlevel 3
Badge +5
Hi @tiagolbassani, I don’t think there is a chart that can give you that result, but the taxonomy export which I explained in my initial response should give you that information.
If that’s not what you’re looking for, maybe you can explain what you plan to do once you have this report. What is your use case for wanting this data? What will you do with it once you have it?
