Question
Event properties not set flutter web
I am developing a flutter web application.
I am tracking events using the flutter sdk version 3.14.0. The events are tracked and work.
The issue is with event properties: they are not tracked. The JSON sent does not contain them.
Here is how I track an event:
Amplitude.getInstance("instance_name").logEvent(
"activity_create",
"activity_type": type.toString(),
null,
null,
false,
It looks a little bit different than the guide but that is because the code in the guide is outdated - using
analytics.logEvent('MyApp startup', eventProperties: {
'friend_num': 10,
'is_heavy_user': true
throws compile errors.
Any idea on what might be wrong?
Be the first to reply!
