Dynamically generated data
  • 7 February 2023
  • 264 views
Can anyone point me to dev documentation that outlines how to capture dynamically populated data for an event? I have a developer that wants to understand how to capture activity on a page that generates different examples depending on what type of file is chosen.
Best answer by timothy-permutable 8 February 2023, 10:55
Sounds to me like can just be an event property, so the tracking event would look something like:
   "name":"Example Generated",
   "event_properties":{
      "example":"value",
      "file_type":"jpg"
Thanks for stepping in @timothy-permutable 😁
Userlevel 2
Badge +3
Hello @RavenMoore that’s a great question and Thank you @timothy-permutable for the great suggestion. Please relay to the developer to try use the suggestion as it should work without issue. If you encounter any issues, please ping me here.
@timothy-permutable  than you so much for the reply - I’ve already shared it with the developer and our internal community. Much appreciated!
