Hello
I have read about creating cohorts based on users having performed a certain event a certain number of times.
For instance, if I were to to look at users that have more than 500 page views in the last 7 days, I could assume this is the most active top 25% or top 10% of my users.
However, in some time that same threshold that right now is the watershed of the top 25%, could return something completely different: maybe top 30%, maybe top 50%.
Therefor, is there a way to have a cohort that will always include the users belonging to a certain relative quartile or percentile, not users above (or below) a certain absolute threshold?
Hi
AFAIK, currently for creating dynamic cohort based on the conditions you mentioned isn’t supported yet.
The only options pertaining to event count looks to be absolute in number , except the relative count parameter. But I don’t this this one is applicable to your use case.
However, you can always create a static cohort from a datapoint within your selected time range using custom formulas ( like percentile ) or distribution of property value if that fits your use case.
