DAU/MAU Chart
  • 29 July 2022
  • 8 replies
  • 1540 views
Userlevel 1
Hi community,
I’m trying to create something like the attached picture
is it as simple as looking at unique users group by week?
trying tp create something like this where i assume its a rolling period?
Best answer by Saish Redkar 29 July 2022, 17:26
Hey @Omriko
You can use this custom formula to chart out DAU/MAU  :
UNIQUES(A)/ROLLWIN(UNIQUES, A, 30)
You can read more on these in the following posts -
Userlevel 1
Hey @Omriko
Thank you, and if i want the flat numbers of the window, just remove the first part right (nominator)?
Yea, ROLLWIN(UNIQUES, A, 30) will give you rolling 30 day uniques per datapoint.
Userlevel 1
I have another question, sorry as I'm a bit confused.
If I wanted the daily active users, just as simple as that, what would I need to do?
I want to see daily active users not events..
Should I use the segmentation chart → any active event -→ group by user ID?
@Saish Redkar
@Omriko
Responded in this
@Saish Redkar i’m using your UNIQUES(A)/ROLLWIN(UNIQUES, A, 30) but as a followup to this, i’d want to take out non-working days to prevent this chart behavior:
which is caused by weekends when close to zero users are using our B2B saas tool 😁.
Any thoughts?
update: i’ve just read up here that it’s not possible and would be a feature request
@klaas
They now have the “Event Day of Week” property filter wherein you can chose the days if you have access to that. Not sure if this is GA to all customers or not yet.
I tried charting the 30 day rolling win formula - with weekends vs without weekends in this demo chart
So I’m assuming every datapoint in there will have the rolling sum of the past 30 days excluding any data from a Saturday and a Sunday.
Hope this helps
