Data export to redshift failing for multiple projects.
  • 1 May 2023
  • 79 views
I’m not able to see data export for the new project on redshift, should i have to create a new one?
If yes, it doesn’t allow me to change the project ID when entering the credentials for the data export.
Best answer by Shashikiran R 2 May 2023, 07:34
Got it working, had to change the project and re-integrate redshift.
@Shashikiran R whew, glad that it’s working for you. Nice job troubleshooting this!
