Compilation error after generating code
  • 5 October 2022
  • 119 views
Userlevel 2
I am trying to follow the documentation here: https://www.docs.developers.amplitude.com/data/sdks/java/ampli/#track
generating code into a backend kotlin project, similar to this example https://github.com/amplitude/ampli-examples/tree/main/jre/kotlin/AmpliApp
However when I generate the code there is a compilation error in the generated file Ampli.kt, line 207
    open fun identify(userId: String?, event: Identify? = null, options: EventOptions? = null, extra: MiddlewareExtra? = null) {
if (!this.isInitializedAndEnabled()) {
return
val amplitudeEvent = this.createAmplitudeEvent(event?.eventType, event?.options, options, userId)
amplitudeEvent.userProperties = this.getEventPropertiesJson(event)
this._client?.logEvent(amplitudeEvent, extra)
the problem is that event is a nullable type.
In the example repo i pasted above, this argument is non-nullable
Best answer by Amplitude Admin 12 October 2022, 17:11
Userlevel 2
I have noticed that this section of code only generates if you specify some user properties
Hi @KatSharp, Thank you for writing this post! Please allow me to check this internally and get back to you!
Userlevel 2
there are also some compiler warnings, like usage of deprecated methods.
Plus it fails a bunch of tests run by common tools, such as detekt.
It would be nice is the code generated adhered to these checks
