Cohort by conversion rate?
  • 18 August 2021
  • 50 views
Hi! I’m new to the platform and I was wondering whether I could create a cohort based on a particular conversion rate.
An example would be if I wanted to study the behaviors (and events, etc) of those with a conversion rate (eg. Purchase) above a particular % or on a top percentile.
Maybe I am looking at this the wrong way and there is a tool to do this already baked in :)
Best answer by Saish Redkar 18 August 2021, 23:20
Welcome to Amplitude, @amplitude  :wink:
If I’m understanding your use case correctly, you can use the Microscope's Create Cohort option to create a cohort from a data point you selected from your Funnel chart.
Create a cohort from Microscope
Depending on how specific you want your use case to be in terms of choosing the %, you might have to switch between the Conversion and Conversion Over Time view to see which one fits the best.
Thank you, @Saish Redkar! That works :)
