Hey @martin
As per the docs, bulk editing your schema is only available for organizations who have purchased the Govern Add-on. Also, you must be a manager or admin to make changes to the Schema.
If both the above conditions are checked on your end and there is no specific error message, then I think you shouldn’t have any issues unless it’s some ongoing Amplitude bug.
I’ll let @Denis Holmes take a closer look at this one.
Hi @Saish Redkar !
Thanks for the answer. How much would it cost to purchased the Govern Add-on to do this specific task ?
Hey @martin
I’m not sure of the pricing structure here . If you are already on an Enterprise plan, then your Customer Success Manager should be able to help you with that.
Hi @martin,
@Saish Redkar is absolutely correct that you would need Govern Add-on for bulk editing your schema. Thanks a lot, Saish!
If you would like me to connect you with our Sales team to discuss the Govern Add-on purchase, please let me know. Looking forward to hearing back from you!
Kind regards,
Hi !
Thanks for your help !
I’ve finally found a workaround by reading this tutorial: https://developers.amplitude.com/docs/self-data-backfill-guide
