Bounce rate and scroll web event
  • 5 September 2022
  • 690 views
Hey everybody!
Someone can tell me if it is possible to see bounce rate web event or scroll web event in Amplitude?
Thanks in advance!
Hi @Marta Catalá
Are you looking ways to measure bounce rate in Amplitude or more like an auto trigger event support for bounce rate/ scroll down on a specific web page?
Here are some posts which might help you -
Thank you, Saish! Your resources have been very helpful for me. I have built a dashboard similar to the it appears in the solution of the second case you shared.
Here it is: https://analytics.amplitude.com/erudit/chart/y0u74qw?source=redirect%3A%20chart%20saved
I have a question related the dashboard that they share on the case. Why I do not have the event “start session” available in my environment? Here you can see they use start sessions instead of page view to check the bounce rate https://analytics.amplitude.com/demo/chart/new/iecpr2t
Hi @Marta Catalá
The Start Session events are something which need to enabled only via the iOS/Android SDK as highlighted in this doc.
Thank you, Saish! I have share those resources with my dev team. I really appreciare your work on here!
