Hello.
Is it possible to set autocapture directly through the amplitude template in GTM? I can't find such an option.
Hi Michał,
Thank you for your question!
This is Liping Yin from Amplitude Technical Support Team. I am happy to help!
May I know are you referring to server side GTM template or client side GTM template?
Looking forward to hearing from you!
Best regards,
Liping Yin | Technical Support Engineer
Amplitude
Hi Michał,
Best regards,
Amplitude
Hello there.
I’m referring to client side GTM template. I assume that I could just do this in GTM tag:
<script>
window.amplitude.init("AMPLITUDE_API_KEY", {
autocapture: { elementInteractions: true }
</script>
but I believe this is not the best way to do so.
