We are looking for an MMP (Mobile Measurement Partner) for our Apple Search Ads campaigns. Could Amplitude be such an MMP? Are there any such cases?
Hi @maximuss24 ,
Thanks for writing into Community! My name is Denis and I will be happy to help you!
Amplitude has plenty of Attribution partners such as AppsFlyer or Adjust. Attribution basically allow for additional data to be added to a customer such as an Install event or Uninstall, for example. They can also use our Attribution API to send attribution data but most would go with a partner such as AppsFlyer.
Here is a list of our partners: https://amplitude.com/partners.
To set up web attribution via our JavaScript SDK, see the following documentation: https://amplitude.zendesk.com/hc/en-us/articles/215131888-Web-Attribution
To cover our bases, I'd like to go over how the AppsFlyer<>Amplitude integration works:
AppsFlyer uses the Amplitude Attribution API to send data to Amplitude. We store all attribution events but do not display all of these events in the Amplitude UI. Attribution events will only show up in Amplitude once Amplitude matches the AppsFlyer event to an existing Amplitude user. If we receive non-attribution events with user information that matches the attribution events, the attribution events will then be ingested into Amplitude and subsequently be displayed in the UI. Otherwise, the attribution event will be dropped. This allows attribution information to be sent without worrying about polluting Amplitude with events from people who never actually use the app.
There are a few key points to keep in mind:
  • Attribution is matched to Amplitude users/events via the Advertising ID (IDFA/IDFV or ADID). Therefore, you must send the Advertising ID for attribution requests and you must set the idfa, idfv, and adid fields for users in Amplitude as the Advertising ID. If you are using the iOS SDK or Android SDK, you can enable tracking of the Advertising ID by following the instructions linked here IOS SDK  and here Android SDK. If you are using JS SDK or React Native, these do not have the functionality to collect Advertising ID automatically due to Google's and Apple's privacy rules around advertising ID and web tracking. You will have to send the Advertising ID through our HTTP API endpoint so that Amplitude can match attribution data/events. See keys in our HTTP API V2 doc.
  • If attribution events cannot be matched to an existing user then it is held for up to 72 hours for potential user matching. If an event is not logged for a matching user within 72 hours of receiving the attribution data, then the attribution data will be dropped.
To summarize, in order for a AppsFlyer event to show up in Amplitude, there must be a non-attribution event that has a matching Advertising ID already in Amplitude or sent to Amplitude within 72 hours of receiving the AppsFlyer event. Lack of Advertising ID and lack of matching events are the two most common reasons that attribution events do not make it into Amplitude.
Hope this information is helpful! Let me know if you have any questions. I would also recommend this marvellous article by Serene if you need to troubleshoot attribution in the feature!
Hi @Denis Holmes! Thank you very much for this post. The information is really helpful:thumbsup:
My pleasure!
