I used ampli to generate typescript file.
But generated file does not pass our typescript checker.
(Error will vary based on tsconfig.json)
I would be nice generated typescript file contains “// @ts-nocheck” to skip typescript check
seeing this too, any updates on this issue ?
Hello
Would you mind providing the following information, please?
"typescript": "4.0.8",
@amplitude/ampli/1.31.5 darwin-arm64 node-v12.22.12
Hello
Currently working with the engineering team on this. By chance do you have a screenshot of the error you’re seeing?
Hope to hear from you soon!
hi,
when generating the ampli wrapper , we get this ts error in the code in the ‘load’ method -> “Property 'configuration' does not exist on type '{ configuration?: BrowserOptions; }”
Hi
/* tslint:disable */
at the top of /ampli/index.ts to be // @ts-nocheck
? Let me know if that helps with the current file that is returning the error.ampli pull
and the issue shouldn’t be there.
For #1 would be good for us to know if you could do us the favor in trying that out. Thank you!
Hey Eddie,
