UNIQUES count where ROLLING SUM > n
  • 6 June 2023
  • 5 replies
  • 128 views
Hello
I know I can create a computation where I get users who performed action in the last N days and then filter the number of actions.
However, I want to get the number of users who performed the action N times in the rolling N days.
Is it possible to achieve? I attached the SQL that is achieving what I want to achieve in Amplitude.
SELECT date, COUNT(DISTINCT user_id) FROM (
SELECT
user_id,
date,
SUM(score) OVER (
PARTITION BY user_id
ORDER BY date
ROWS BETWEEN 6 PRECEDING AND CURRENT ROW
) AS rolling_7_day_sum
FROM table_name
WHERE rolling_7_day_sum > 25
The sql assumes that there is a row for every day for each user
Best answer by JennRu 8 June 2023, 21:10
Hi @Lori
I’m not sure if I’m oversimplifying your use case here, but you can build this clause in a cohort definition or a user segment as seen below.
This rolling cohort definition will give you users who have performed the action N times over the last N days.
Yes, unfortunately this is a oversimplified solution.
What I’d like is to see a line chart, where if I look at June 5th I get the UNIQUES of users who performed action N times between May 30th and June 5th. If I look on June 1st, I get the UNIQUES of users who performed action N times between May 26th and June 1st. All in one chart.
Basically the rolling SUM of the 7 day window from the one that I am investigating on a line chart.
 Hi @Lori could you set this up with an in-line segment in an event segmentation chart
who performed action x > 25 times
any time in each day
rolling over 7 days
And then set the event in the segmentation module, group on User ID, and apply formula PROPCOUNT(A1)
That’ll display a line chart of the unique count of eligible users who met the ROLLWIN + Count threshold criteria.
Let me know if this helps!
Thanks for jumping in @JennRu !
Yes, That does solve the problem, thank you @JennRu
